Michaelx Posted September 15, 2017 Share Posted September 15, 2017 Ver X8. Here's what I'm trying to do. A floating soffit (12" below ceiling) with complex shape and rounded corners. I seems you can't make rounded corners on a soffit. No problem. I can do what I need with polyline solid or custom counter top and it comes out just like I want, but I can't place a recessed ceiling light in/under either of those. I've changed the layer to Cabinet, Soffit but still can't place a light. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 15, 2017 Share Posted September 15, 2017 Open the light DBX and set the Offset from ceiling under the General tab and you should be fine. 1 Link to comment Share on other sites More sharing options...
Michaelx Posted September 15, 2017 Author Share Posted September 15, 2017 42 minutes ago, Chopsaw said: Open the light DBX and set the Offset from ceiling under the General tab and you should be fine. Brilliant! Thanks! Link to comment Share on other sites More sharing options...
