Duplicating Information on just Some Layout Pages
Joe_Carrick
By having more than one Layout Page Template, you can have extra information displayed on some of the Layout Sheets.  For Example, if you wanted "Exterior Notes" displayed on all the Elevation Sheets:
  • Open Page "0"
  • Select everything (Border, Title Block, etc) and copy to the clip board.
  • Create a new Layout Page and Paste-Hold-Position
  • Right Click on this Page in the Project Browser and Edit the Page Information
  • Title = "Elevation Template", check "Use as Template"
  • Add the "Elevation Notes" to this Page.
For each of your Elevation Pages select this Template as the one to use.
In the future if you need to change any of those notes, you just edit them on the template and they will be changed on all the sheets that use that Template.
This is just one example - and maybe one that isn't needed but you get the idea.  You could use it for a series of sheet that all nee the same graphic legend (Electrical for example).
