Wardrobes with sliding doors
EspiQ_BNG_IND
Make your own door symbol and adjust the origin. Attached plan has a couple of options to point you in the right direction. Open plan, open cabinet DBXs, open door symbol dbx (not object) and read up on symbols in reference manual.
These don't operate. To do that with just cabinets you'd  need to have two cabinets-one open, one closed, on top of each other on different layers.
You could make some wall definitions, build the cabinet from walls, room with shelf ceiling. You will need to mess with the door symbol quite a bit. In the long run not worth the trouble IMO but a start is included.
BTW this kind of question belongs in the Q& A section. Also please add version you are using and computer information to your signature.
SLiders.plan
