wood between ceiling and wall in basement not wanted
holm0326
If you look closely at the image, it can be seen that unfinished wood is showing where my basement ceiling and basement wall connects in Home Designer Suite 2018. I can't seem to fix it after trying different things. I am lost. I'm trying to finish this basement. Any suggestions as to why this is occurring? This seen unfinished wood is appears along the top of all four basement walls. Any help would be appreciated.
The most common cause is on your "Structure Tab" in the basement's Room Specification Dialog the ceiling thickness is set to a value of "zero" thickness (this causes no ceiling to appear in camera views). No matter the actual cause, it is always to be found in improper settings in dialog boxes or Default Settings, get your settings right then all else will also be right.
