Anders42 Posted September 1, 2017 Share Posted September 1, 2017 Beginner dimensioning question: I'm following along with a CA interior design tutorial. I drop all the interior + exterior dimensions on to the plan - but when I try to adjust the dimensions to the correct lengths, the wrong walls always move. - I realize that there is a tool that indicates which direction you can move the wall - but it still seems to move the wrong walls. In the attached screen shot - I'm copying the tutorial on the left - but when I try to change the 2 small rooms on the right - it will change the exterior wall length instead of the interior wall on one of the smaller rooms. Even though I am clicking on the 44" dimension - it will still move the full exterior wall (which keeps jumping off of 32' final - which is how it should stay). Beginner questions- but I can't seem to get past this dimensioning issue! Link to comment Share on other sites More sharing options...
MarkMc Posted September 1, 2017 Share Posted September 1, 2017 select the wall you want to move THEN click the dimension. Link to comment Share on other sites More sharing options...
Anders42 Posted September 1, 2017 Author Share Posted September 1, 2017 Oh boy...that worked! THANK YOU Link to comment Share on other sites More sharing options...
