pjbuilder Posted July 25, 2017 Share Posted July 25, 2017 Does anyone know how I can keep false drawer box from showing up in the sink in X9? Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted July 25, 2017 Share Posted July 25, 2017 9 minutes ago, pjbuilder said: Does anyone know how I can keep false drawer box from showing up in the sink in X9? Thanks if that is all one cabinet and not two as Eric suggests change the separation to a blank area and it will go away. May have to adjust width to make reveals proper. Link to comment Share on other sites More sharing options...
pjbuilder Posted July 25, 2017 Author Share Posted July 25, 2017 Absolutely correct. It was one cabinet I separated vertically to define drawers on one side and doors on the other. By changing the vertical separation to "blank" it disappeared from the sink. Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted July 25, 2017 Share Posted July 25, 2017 1 hour ago, pjbuilder said: Does anyone know how I can keep false drawer box from showing up in the sink in X9? Thanks I thought about this a bit more, played with a little. Depends on what you need- what I suggested works really well with inset cabinets, not so good with overlay if you want doors and such to be accurate. I tried altering a face a few ways so that the separation did not go to the top of the cabinet-not so good, tried a custom symbol for a stile (stiles DON"T go all the way through a cabinet) also NG. Ended up with two cabinets per attached. (I have no idea why the arch block resizes once the sink is centered in it) If I needed a correct schedule for this I'd export it as dae then import as a cabinet symbol. The only problem with that is once it's imported there is very little you can do with it. Some variations. I saved the plan for my own future use. Split vanity3.plan Link to comment Share on other sites More sharing options...
