I'm a newby, so be kind.  :)   I'm looking for symbols for two things electrical.  The first is a generator, which would be placed outside next to the meter socket.  The type I would be most interested in is the Kohler 17kva.   Then I need a symbol for the transfer box, which is a Hoffman style metal box, about 24" x 24" x 10" which would go inside next to the breaker box.
I also have need for some ham related symbols.  Since I'm really in the minority with these, is there an FAQ or paper on how to design these from scratch?
TIA,
Fred
So how does an .skp file integrate into Chief Designer?   Does it have to be converted?
No use the File Menu>Import >3D Symbol>.skp
Different Chief Versions Import different .skp versions so if it can't do it downland a different version  .skp file
Sign in to follow this
    27352
    JBannan
    JBannan
  • Similar Content
    • By PrimeArch
      Hello guys. I made a custom symbols and model for my electrical because CA dont have it.
      I managed to make it but the problem is  they cannot stay side by side.. they will merge  like this
      Btw the can stay side by side if each of em not the same height
      How do i solve this? Please help
    • By BuildingVision
      I have created a column out of Polyline solids and moldings.  Is there any way to get an outlet to place into this surface?  If there is not a way, what are your suggestions on what I do?  It is a dummy column framed out that surrounds a steel post, there is plenty of room for an outlet to be placed within the open interior space.  How do I place the outlet without there being a wall or a cabinet in this location?  Please see the attached image.  The red arrow points to where I would like to place an outlet.
      Thank you for your help!
      Nicole
    • By ChiefuserMathews
      Hi, How do I show a 3 way connection switch for a light at the top and bottom of the stair. Currently the 3 way switch can be shown only on 1 level. unless there is an another option.
      Thanks for the help
    • By lavorhaynie
      I've been an active user of Chief Architect for about 15 years now. I am currently using the X11 and have an SSA.  In all of these years using the software I have been frustrated with a couple things in the electrical area. First was the terrible placement of electrical connectors, they were never placed in a way that was visually appealing. I was always wasting time adjusting the lines after placement just to make them look nice on the plan.  Thank you Chief, in X11 the lines now, most of the time, place in a visually acceptable manner. A great time saver when doing the electrical!
      The second, frustrating issue is the lack of programming to address the floor-to-floor light switching. I have over the years visited ChiefTalk hoping someone had a good solution to address this issue. I have never liked any of the proposed solutions, namely placing the correct 3-way or 4-way switch on each floor then placing cad arcs or splines to represent the electrical connector. I felt it to be a time waster and it just did not feel right using a cad line instead of an electrical connector.
      So, in response to my frustration with floor-to-floor switching I came up with an idea and ran with it. I created two floor-to-floor connector symbols. The symbols are identical except that one is designated as being switched and the other is not switched.  Both are, in plan view, a 2" circle, defined as an electrical item, In 3D they are a 2" clear glass sphere and attach to the ceiling, being virtually invisible in a 3D rendering. When I am doing a floor-to-floor switch connection I place the switched symbol in the stair well then connect the switch to the symbol. The switch then automatically changes to a 3-way. I have a set of text labels that I then place over the switched symbol to indicate the usage of the switch, i.e. "To light above", etc. I have attached an X11 library containing the two floor-to-floor symbols, (switched and not switched), and the text labels I use.
      I hope these will save you a bit of time. Enjoy!
      LaVor
      ELEC CONNECTORS.calibz
    • By LeahPugh
      The callouts for the electrical symbols (threeway, dimmer, timer, etc) do not change scale with the electrical labels. I am working in 1/4" scale and the symbols are tiny. I am receiving complaints from my builder that they cant read the symbols.  Is there a way to change the size on the symbols?
