EliteLiving Posted July 4, 2014 Share Posted July 4, 2014 I'm looking for a resource for architectural columns for contructing pavilions. Otherwise, how can I make custom columns and add them to my library? Link to comment Share on other sites More sharing options...
BryceEngstrom Posted July 4, 2014 Share Posted July 4, 2014 There are quite a few in the Chief Library. There are quite a few in the Sketchup 3D Warehouse online. You can make just about any kind of column you can imagine with molding polylines, polyline solids, etc. Adding them to the library can be done by making a block of these items, or taking a 3D view and going to Tools/Convert to Symbol and adding that to your library. Link to comment Share on other sites More sharing options...
tommy1 Posted July 4, 2014 Share Posted July 4, 2014 If you're wanting to make square columns, I like to use the soffit tool. you can add multiple moldings and 1x profiles as well. Then make a symbol of it. Also, if you assign different materials to everything you add, you'll then be able to apply different materials to each part after you create the symbol. I use a combination of things if I'm making craftsman columns. Link to comment Share on other sites More sharing options...
