Duckling1 Posted May 16, 2017 Share Posted May 16, 2017 Hello, I have a 5600 sqft 2-level residential house that is designed using X9. I need a structural engineer that can sign-off on construction documents for California (94947). Thanks. Mario Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 17, 2017 Share Posted May 17, 2017 WHERE AT IN CALIF. Link to comment Share on other sites More sharing options...
Duckling1 Posted May 17, 2017 Author Share Posted May 17, 2017 The house will be built in Novato, California 94947. Link to comment Share on other sites More sharing options...
jorgearaya Posted May 17, 2017 Share Posted May 17, 2017 Not sure what you're looking for here, I read the post and I'm still confused... Look up your yellow pages for a local structural engineer that can look at your project (paper plans) and produce a proper structural analysis and documents. Then review the provided analysis for proper design, upgrade or downgrade as needed (typically downgrade). Re run the analysis, produce docs, get stamps. Link to comment Share on other sites More sharing options...
Decorationarts Posted May 17, 2017 Share Posted May 17, 2017 Try: Roberto Cortez Engineer Monarch Engineering 301 Georgia Street, Suite 355 A Vallejo, CA 94590 1-888-388-0526 707) 648-9571 (707) 333-1371 rc@monarchengineers.com based in Vallejo, Both a civil and an structural. Used him many times. Link to comment Share on other sites More sharing options...
