Molding under eave, how to?
CA4Ever
Hi, I have problem to place the molding right under the flat eave and I have to move down the molding 3" to make it visible as you look on the right side.  I knew there was a video showing how to but  couldn't find it.  If anyone can help, very much appreciate.
1. Click exterior room just outside of wall on exterior.
2. While this is selected on your bottom toolbar you will have option to create moulding polyline...select this.
3. Set height you want the moulding(s) at.
4. Click on your moulding polyline you created and set your moulding profile and extrude inside of line should be unchecked.
