Room Wall Material
Skip_D
Hi,
Working in X9.
Is there way to define a wall material for a room, and then remove that material from one of the walls?
In my example, I have added bead board wainscot to a bathroom, but do not want the bead board on the glass shower wall.  If I designate the shower wall as 'no room definition, then the bead board would then be inside the shower, so that doesn't work.  Also, I'll want to add tile to the shower wall w/out it being on the glass.
Any thoughts/suggestions?
thanks,
Skip
