amddrafting Posted April 21, 2017 Share Posted April 21, 2017 So since the X9 update we haven't done a Res Check on a house until today and noticed that all of the information we used to gather for that in the Materials list General Section is no longer there. Used to have Ceiling SF, Walls SF, Windows and Doors SF, etc. None of that is there any more. Is there a new setting somewhere that can bring this back or a new Res Check area? The Res Check exporter never worked for us so we just kept doing the same method we always did before but now we can't. Any help would be appreciated. Link to comment Share on other sites More sharing options...
glennw Posted April 22, 2017 Share Posted April 22, 2017 Do you actually have a General section displaying in the ML - or is the whole General section missing? If the whole General section is missing, go up to the toolbar and select Display Options. Make sure the General section is checked. Link to comment Share on other sites More sharing options...
amddrafting Posted April 22, 2017 Author Share Posted April 22, 2017 No it's there, just those specific items, ceiling sf, wall sf. windows, etc are not displayed only linear footage of walls. Link to comment Share on other sites More sharing options...
glennw Posted April 23, 2017 Share Posted April 23, 2017 My last guess without seeing a plan is that you have your rooms defined as Unconditioned areas. Or if you have Use Default set for Conditioned Room, you are using a room type that defaults to Unconditioned (like a Balcony, Attic, Deck, etc). Unconditioned areas are not counted as part of the thermal envelope and thus do not show up as such in the General section of the ML. Otherwise, post the plan. Link to comment Share on other sites More sharing options...
