Temporary dimensions in X6
Shelimar71
Hello,
Is it possible to set up temporary dimensions so that they reference only walls? For some reason my temporary dimensions are messed up and not only are they referencing all the openings etc. I also have duplicate dimensions. Makes it very hard to see the one I want. I found the temporary dimension default options but they don't give many options and haven't helped.
Thanks!
I would suggest placing dimensions to your objects rather than relying on temp dims to place/position them.
Make sure your temp dims are set to both wall sides and to wall dim layer. It appears that the temp dims are referencing the same type object as they should. IE walls selected temp dim to walls, door selected temp dims to wall surfaces both side of door. Same with cabinets, windows etc.
Michael
Chief Architect user since 1997
Current versions used X4, X5, X6
www.MichaelPachDesign.com
