Mono Slab and Slab Rooms
Skubacb
Don't understand this.
In defaults I have selected my foundation to be a monolithic slab.
With say two rooms Chief X9 makes two foundation rooms and names them the same as the room above.  Also, the room are not marked as a monolithic slab.
If I change the room type to SLAB Chief wants to turn off auto rebuilding of the foundation.
Why aren't they all just called a slab room?  Does Chief change anything if they are a slab room or not?
Just confused here as to what Chief is doing.
Room names are more than just a label.  They determine some of the auto build functions.  I would start by changing your FLOOR defaults.  You may also need to define some rooms structure tabs as floor being supplied by foundation room below.
Thanks.  They do work ok and they all have "supplied by foundation room below".  I just don't understand why a foundation "room" in a monolithic pour.  Oh, well guess I should just let Chief do what it wants.  I will try to tell it that the slab is monolithic.
