Skubacb Posted April 12, 2017 Share Posted April 12, 2017 Don't understand this. In defaults I have selected my foundation to be a monolithic slab. With say two rooms Chief X9 makes two foundation rooms and names them the same as the room above. Also, the room are not marked as a monolithic slab. If I change the room type to SLAB Chief wants to turn off auto rebuilding of the foundation. Why aren't they all just called a slab room? Does Chief change anything if they are a slab room or not? Just confused here as to what Chief is doing. Link to comment Share on other sites More sharing options...
javatom Posted April 12, 2017 Share Posted April 12, 2017 Room names are more than just a label. They determine some of the auto build functions. I would start by changing your FLOOR defaults. You may also need to define some rooms structure tabs as floor being supplied by foundation room below. Link to comment Share on other sites More sharing options...
Skubacb Posted April 12, 2017 Author Share Posted April 12, 2017 Thanks. They do work ok and they all have "supplied by foundation room below". I just don't understand why a foundation "room" in a monolithic pour. Oh, well guess I should just let Chief do what it wants. I will try to tell it that the slab is monolithic. Link to comment Share on other sites More sharing options...
