ACADuser Posted April 12, 2017 Share Posted April 12, 2017 Can't seem to figure out why the wall finish layer is missing in this view. Thanks for any suggestions. MacDill RH-Unit B.zip Link to comment Share on other sites More sharing options...
ACADuser Posted April 12, 2017 Author Share Posted April 12, 2017 Thanks for looking. I found that the wall dbx when "Hang Floor Platform Above on Wall" was selected it causes this. I had unchecked it before sending the file but in my view it did not update. Closing the view & reopening it I see the correct wall. The material region was an attempt to fix this. Problem is that in section views I want the Hang Floor Platform Above on Wall checked. If I can repeat the problem I will send to Tech Support. Thanks Link to comment Share on other sites More sharing options...
ACADuser Posted April 12, 2017 Author Share Posted April 12, 2017 OK sending to Tech Suport Link to comment Share on other sites More sharing options...
