JJinLondon Posted April 6, 2017 Share Posted April 6, 2017 The roofs are being done manually. The roof edge exactly meets the siding on the upper roof. If I imbed it at all, it will render with the siding stripped off. If I pull it away the spike if wall from the lower wall only gets bigger. I suspect this is an issue because the garage is sunken. I'm sure someone has resolved this but I have searched the forums and must just be using the wrong key words to catch it. Any help would be appreciated Link to comment Share on other sites More sharing options...
ShaneK Posted April 6, 2017 Share Posted April 6, 2017 Post the plan and it will be fixed. More than likely a Wall connection problem Link to comment Share on other sites More sharing options...
