Lights In Steps
Yes. but if you use .skp files then you also have to place an "added light source" so that object will also emit light in renderings (Chief lighting objects already have a light source built into them, symbols made by other may or may not have a light source built in).
I have made poly-line solid objects and just assigned a 100%  "emmisive" setting to the material assigned to them to create the apparency of a light source as well.
