selecting similar objects
Chris_Kelly
I have been playing around with Revit a little bit lately and I believe they have a tool that allows you to select similar objects at once. For example, if i need to change the heights on some of the windows on a floor, I can select all the similar ones in one shot rather than selecting them manually. Is there a way to do this in chief that I am unaware of?
Check out the Match Properties tool.
Note that you can also activate a tool for any group of items (the window tool for example) and then hold down shift and marquis select any area(s) of the plan and only that particular object type will be selected.
