Intersected/Contained objects marquee
stevesakiwi
Is there a hotkey or work around that bypasses the need to go into Preferences to select how the selection marquee works. ie:- selected objects or contained objects.
It's a pity CA hasn't adopted the selection process used by Revit & ArchiCAD:- drag marquee from the left to select contained objects or drag marquee from right to select intersected objects.
TIA....Steve
Thanks, but I was hoping there was a way of avoiding going into Preferences.....I have been setting up Hot Keys & I had hoped that there was an option there....maybe CA needs to consider how Revit & ArchiCAD utilize this command.....their process is very simple & helpful when drawing.
