Terrain line elevation
conwaynorth1
The layers Terrain, Primary Contours and Terrain, Secondary Contours should be turned on. Adjust the layer Text Style to control the size of the contour label. Also, in the Terrain Specification dbx, the Contours>Label Options can be used to toggle the display of the contour labels on/off.
