Material Regions on elevations dissapearing
WhistlerBuilder
When I add a material region to front and rear elevations they show up in the location I draw them on. When I draw a material region on a side elevation, after converting the shape to "Material Region" it moves the block from the face of the drawing to the middle of the building for some reason. Since I am trying to apply a material region to the siding and not the middle of the building this is a big problem. Not only does the material region shape dissapear, but I can no longer select it as its been moved into the building. This is incredibly frustrating!
Any tips on how to fix this?
How then do you move it from the middle of the building back to the siding face it was originally drawn on? I found out it was moving it into the building by drawing a different material region that extended outside the building perimeter so that the material region would show up in a 3D view. For some reason the software keeps moving the material region into the center of the building. It is doing this on multiple drawings/plans.
