ChiefGrego Posted January 15, 2017 Share Posted January 15, 2017 Version X8 Ok, so I have spent hours trying to create what seems like should be a fairly common and very simple box window. I have tried it automatically and manually. I've searched for threads which I found in the past, Looked in both the user and reference manuals. box window needs (2) 3060 SH twin. No windows on the side Header height is 7'10 3/4". The window is at the breakfast area and has a 20" seat above the finished floor. The main wall is brick but under the window box is siding as is the box. The box fits under the overhang so is only 12" deep. I have been trying to create this because I am trying to learn Chief. Trouble I'm having is with the two mulled windows and the siding under the box....any direction will help Thanks Link to comment Share on other sites More sharing options...
ChiefGrego Posted January 15, 2017 Author Share Posted January 15, 2017 That is exactly what I am trying to do....should be simple right? I had the siding underneath once.....need the twin window and trim boards Link to comment Share on other sites More sharing options...
Francois Posted January 15, 2017 Share Posted January 15, 2017 Once you have placed the twin windows, select them both and look for the icon to mull them (cube with blue and grey sides) Link to comment Share on other sites More sharing options...
ChiefGrego Posted January 15, 2017 Author Share Posted January 15, 2017 Solver Correct! This is a set of plans from a volume builder that I have had for 11 years. There are 17 sheets total. (foundation through framing) The goal is, to re-draw them using Chief and as identical as possible. I already compromised because I already gave up on the angled "fur down" (if that is correct terminology) that you have just drawn. ( Now I realize it can be done, Is this an automatic window or did you draw it manually, or combination? There is another box on the left elevation that is a 4050 PW TEMP over the Tub of the master bath. Same window except it has a single window. Now look at the front elevation. no windows on the side. I wonder why the program the original draftsman used didn't pick up the windows. Francios, It is my question. I have tried everything I can think of to drop an additional window into an automatic box window and can not do it. The side elevations do not show brick under the window. instead the fur down goes to the brick ledge. question is how much detail is necessary. Should the brick ledge stop and start at the window or continue through. Thanks for looking at this! ChiefGrego Link to comment Share on other sites More sharing options...
Francois Posted January 15, 2017 Share Posted January 15, 2017 Have you tried to create a room and raise the floor? I can mull two windows in a wall but I have not been able to install a second window on a box window. * Link to comment Share on other sites More sharing options...
ChiefGrego Posted January 16, 2017 Author Share Posted January 16, 2017 Francois, Manually is only way I can find so yes that is what I'm doing now. I found a post by David Potter talking about a corner box window that helped with the manual window..... I'm closer than ever...Solver already knows how to do it but he's only leaving hints. Solver, Floor is raised supported by the framing beneath. So exterior poly line.... solid is frame support. . There is no detail in the plans.....the framer will know what to do with it. Now I'm thinking about the detail....but I'm not there yet. Thanks for the input Link to comment Share on other sites More sharing options...
