Wall line weight - Global?
brian-sdesign
It depends on how you set up your walls in the first place. Each layer allows you to define the line weight By Layer:
...so if you set up your walls to use this feature, then all you have to do is change the Layer line weight. Otherwise, you'll have to re-define every Wall Type.
