Designer100 Posted December 8, 2016 Share Posted December 8, 2016 I am just doing a 3D rendering of a bldg. under construction. it is 3 levels with 4 level attic (8ft clg where stair landing is) with stair well to bacony. When I call out attic at 4th level it lowers level 3 ceiling (9 ft ht), 2nd level (10 ft), first level 9 ft. . I just mainly have drawin exterior walls with opening to be able to design at 3D rendeing. 8 /12 roof pitch over 3rd level masteer bedroom area for atttic. Then 4th level 8 ft ceiling attic going to bacony where ac unit will go with concrete waterproof floor. I have 5 of these rendering to do and wanted to see how long one will take before signing agreement with client. tomorrow. Any help would be apprectiated . Chief x8, Windows 10. Keating 12.2016.plan Link to comment Share on other sites More sharing options...
BrownTiger Posted December 8, 2016 Share Posted December 8, 2016 If I understand correctly, it is because your "open to below" room at the floor 3 has the wrong ceiling (B) value: 358 5/8", and it should be 377 3/8" - "Open to below rooms" should be adjusted by Floor Structure (L) value +18 3/4". Link to comment Share on other sites More sharing options...
Designer100 Posted January 4, 2017 Author Share Posted January 4, 2017 Thank you Link to comment Share on other sites More sharing options...
Designer100 Posted January 4, 2017 Author Share Posted January 4, 2017 Brown Tiger, I did not get project, but thank you for your input. Link to comment Share on other sites More sharing options...
