johnny Posted November 11, 2016 Share Posted November 11, 2016 I'm growing more and more frustrated with Chief and the inability to adequately re-use resources between plan files, which contain multiple types of objects. I realize you can block certain objects, but so often I have a composite group which may include walls or other "non-blockable" items in Chief. Further, those items dont even copy and paste well without a massive amount of duplication of efforts on properly reconnecting everything so it works - which can often take longer than simply remaking or reassembling the entire group. Common composite modeling resources Id like to reuse with ease are: - Stairs, with shaped knee walls, solids, etc - Fireplace surrounds that include wall elements. - Box windows with paneling - Window configurations with polysolids - Bookshelves that include wall build-outs. -and more Has anyone found a way around this or is it a complete fail on Chief's part? Link to comment Share on other sites More sharing options...
Richard_Morrison Posted November 11, 2016 Share Posted November 11, 2016 About the only thing you can do is have a separate "warehouse" plan with these items, which then will be available to copy-paste. I'm not sure what problems you're having with the copy-paste process, but I don't think you've listed anything that is a serious problem. Link to comment Share on other sites More sharing options...
johnny Posted November 11, 2016 Author Share Posted November 11, 2016 Ill put some pictures/examples together and let you guys see what I am talking about. I've tried to isolate the composite in a new file, and that does "help" - but then to take the next step and keep everything in place while I precisely locate the group in an existing file just doesn't work well. Link to comment Share on other sites More sharing options...
johnny Posted November 12, 2016 Author Share Posted November 12, 2016 Here is a good example. I have a stair "system" I want to reuse in other plans, and I copied first into a blank plan (as you mentioned) and then into a new plan I was working on. Id call this a fail. Getting in there and cleaning this up is nearly the effort to rebuild. Link to comment Share on other sites More sharing options...
