HumbleChief Posted November 8, 2016 Share Posted November 8, 2016 Just heard back from tech support regarding the double slabs being built on the plan attached in the thread below and it turns out I had defined a wall as a 29" thick wall that Chief could not resolve. They recommended 2 walls instead and I am not sure how large a wall can be spec'd before Chief doesn't play nice but in case someone else runs into a similar problem look for a thick wall and either delete or create using smaller walls. https://chieftalk.chiefarchitect.com/index.php?/topic/11638-disappearing-flooring/ Link to comment Share on other sites More sharing options...
