Sara516 Posted November 4, 2016 Share Posted November 4, 2016 Hi everyone, Is there any way to edit/connect an item in my Chief Library to a layer of my choice vs. the default layer it is connected to? For example the Chief Architect registers/vents are on the fixtures layer but I would like it to be on the electrical layer. Thanks in advance! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 5, 2016 Share Posted November 5, 2016 Copy to your user Library. You can change the Layer there. Then you just select from that Library location 1 Link to comment Share on other sites More sharing options...
Sara516 Posted November 7, 2016 Author Share Posted November 7, 2016 Thank you! Problem solved! Link to comment Share on other sites More sharing options...
