Stevblev Posted October 23, 2016 Share Posted October 23, 2016 Hello everyone. Im in the process of designing my house with home designer suite and am having a problem with my loft area. I need the whole interior wall to be open, as I plan on having a staircase follow the 1st floor wall and a railing across the whole 2nd floor wall. Right now I have an attic wall, and an exterior wall on that side of the loft set behind the attic wall. I feel like I should make the attic wall invisible, but what do I do with the exterior wall to keep it from coming down through the roof line? Link to comment Share on other sites More sharing options...
Chopsaw Posted October 23, 2016 Share Posted October 23, 2016 This should be posted in the Home Talk Forum next time. https://hometalk.chiefarchitect.com/ A couple of thing you could try if the Designer Suite will do it. Open Wall Specification under the Roof tab and select "Roof cuts wall at Bottom" and or put a doorway at the end of your hall sized to the interior dimensions of the hallway with no casing or threshold. Link to comment Share on other sites More sharing options...
