X6 Int partiton walls
wm_smith
Go to solution Solved by wm_smith,
OK I'm stuck. I have just started with X6
In previous versions of CA you could grab the handles on an interior wall and lower the wall. You know for like a 42" an interior partition wall. Well when I grab the handle on an interior wall in x6 the whole ceiling comes down with the wall.
What am I missing? What has changed.
Ed
You are probably grabbing the Room rather than the wall - it's a setting in Preferences I believe.  If that's the case, just press the Tab Key to get to the wall.
OTOH, once you have actually selected the wall - you can open it and change it to a half wall (same as a Solid Railing) and set the height to whatever you want.
