rodhealydesign Posted August 14, 2016 Share Posted August 14, 2016 Hi guys Just wondering if there is an easy way to edit the shape of full height cabinet? I just need to fill in the corner space pictured in screenshot, ideally just selecting points and dragging them where I want manually. Have been looking through knowledge base, but nothing stood out :-/ Appreciate any help I can get. Cheers, Rod Link to comment Share on other sites More sharing options...
Solution MarkMc Posted August 14, 2016 Solution Share Posted August 14, 2016 Angle front, make blank, custom back, rotate, if I remember correctly may need to fake toe space. IRL I'd just use a cabinet front, filler or shelves. Link to comment Share on other sites More sharing options...
rodhealydesign Posted August 15, 2016 Author Share Posted August 15, 2016 Hi Mark Thanks for your feedback. Showing my in experience of the program here, but would you have a link/tag to a video that demonstrates this, or knowledge base? Regards, Rod Link to comment Share on other sites More sharing options...
rodhealydesign Posted August 15, 2016 Author Share Posted August 15, 2016 *inexperience that would be :-/ Link to comment Share on other sites More sharing options...
MarkMc Posted August 15, 2016 Share Posted August 15, 2016 Open cabinet-hit "F1"-select "general" to see where to configure shape of cabinet, select "front side back panel" will get the information on how to adjust cabinet faces and such. There is nothing listed anywhere about reversing the cabinet to get what you want. It is a matter of thinking about how to get what you want from what the program will do. Attached a sample for you. Link to comment Share on other sites More sharing options...
rodhealydesign Posted August 18, 2016 Author Share Posted August 18, 2016 Hi Mark I've had a chance to look into adjusting the cabinet settings. I opened up your plan and repeated settings etc. Thanks a lot, that has given me a much better understanding of how it works. Side note: I have attached a completed render to see the fruits of your labour. Much appreciated. Rod Link to comment Share on other sites More sharing options...
