Sign in to follow this
davidlgoss
help to lower first floor, plan attached
Help ! so i asked the other day about changing floor heights which as everyone said , i did out of the defaults dbx, i need to get my lower floor down to 133" so my second floor ceiling  finish is under 20'
i can change the defaults but it doesnt seen to effect my story pole dimensions on my front elevation, if i go into the rooms it says its at 135, which is what i originally drew it at,if i click default it will change that room but not the whole floor, but i cant for the life of me how find how to adjust it , it wont even let me do it room by room   plans attached if some can tell me what im doing wrong,   thanks agian
1670 15TH ST ADDITION CURRENT 2 20.1.plan
thanks for your help, it was driving me nuts !
No problem.
Using "Ceiling Elevation" and "Floor Elevation" within the "match properties" command is an immense help.
Change settings in Edit>Default Settings, then Edit>Reset to Defaults.
    27472
    justinsmith73
    justinsmith73
