SketchArchitect
Shed Dormer - Side Walls
Hi All,
Back at it... using the polyline hole-in-roof method I was taught a while back by one of you fine folks.  This time the shed dormer is not the whole width of the house and so I don't get an enclosed finished dormer.  (see attached file)  Please advise.
Warm Regards,
Stu
Brugman Project.plan
Set your left and right walls of the washroom as siding-4/6, and then hit the reverse layer button so the siding is on the outside.
Set the two rooms on either side of the bathroom to "attic".
this is good...  but I'm still having some difficulty with a couple things...  on the inside, there are elements of exterior siding...   and the exterior siding will not take color changes....
I believe it's a bug.You can use the Adjust Material Definition tool to change the color.
If you change the default exterior wall definition first to any color other than the default, then draw in the walls, it works, and you can also paint them afterwards.
    27465
    SuzLeigh
    SuzLeigh
