RobUSMC Posted June 23, 2016 Share Posted June 23, 2016 Does anyone have symbols / textures or know of a good source for good seamless textures that doesn't need to be cropped and tweaked just to get a decent look in Raytrace. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 23, 2016 Share Posted June 23, 2016 Such things require perseverance and the intention to get a product. This is a good place to start: http://www.mosa.com/generator/#search There are supplemental libraries you can download from the Chief Architect library catalog areas, check those out as well as the "Dal Tile" catalog. I am sure more sources can be located on line by search. DJP Link to comment Share on other sites More sharing options...
sfarekas Posted August 11, 2016 Share Posted August 11, 2016 I've actually been using the Brick Herringbone (under pavers of the core catalog) and blending it with a color that is appropriate. This at least gets a good look in ray trace, with grout lines. This is only good for solid colors though. . Maybe this will be on the next version of Chief? I feel that it's a common application. -Sima CA x8 Link to comment Share on other sites More sharing options...
