Posts
255 -
Joined
Last visited
Content Type
Profiles
Everything posted by Designers_Ink
Grass reflections on interior walls?
Designers_Ink replied to Larry_Sweeney's topic in General Q & A
Try lowing your sunlight level to about 1000 and see if that helps -
OSB Sheathing showing through standing seam metal roof
Designers_Ink replied to MN_JohnH's topic in General Q & A
It is actually a reflection that looks like OSB. Change the material to a matte finish or change the roughness to 100% using the rainbow tool, and it goes away.- 6 replies
- 1
- stnading seam
- osb
(and 3 more)
Tagged with:
From the album: Designer's Ink Samples
Radeon W6800 System Crashes Reliably in Ray-Trace Views
Designers_Ink replied to williambentley2's topic in General Q & A
OK. We have been seeing the same issue with the Intel 14900K, but it sounds like your issue may be different. With those chips you had to back the Performance Active-Core Ratio (P-Core) down a bit to resolve the issue. When the graphics card called for more power, it cause the CPU to shut down the computer to protect it. I found the best solutions to try came from gaming forums since those guys deal a lot with high end systems and spend a lot of time tweaking things. Best of luck to you. I know it is frustrating. -
What CPU chip are you running? -
Client Portal and Project Management Software Recommendations
Designers_Ink replied to DefinedDesign's topic in General Q & A
I have had great luck with Honeybook for my client portal. It keeps all of our communications and files in one centralized place and once you set it up with personalized templates, it make onboarding and and obtaining signed contracts a breeze. It offers invoicing, but I still use QuickBooks for that. It is not perfect, but they seem to be pumping out new features pretty often, and they are open to suggestions for improvements. -
