Sign in to follow this
Tedhouseplans
Needing help finishing up our House Plans in Chief Architect X8
Hello, we are needing help in wrapping up our house plans. We need help with the roof, layers, and details. We have it about 80% complete, but needing help for about 1-2hrs. Willing to pay a good hourly price. Please let me know if anyone is interested. Thanks, Ted
    27858
    danmor
    danmor
  • Similar Content
    • By ilastu
      I successfully imported the floor plan for a house from a dwg file, however I have not found a way to convert the roof drawing into 3D. Is there a way to do that? I am using the X11 version.
    • By DCB123
      Hello, my name is Doug, as I am a Chief Arch’l Cad Designer, looking to help other contractors, builders and Chief users with their residential projects, 3D models, plans, walkthroughs, photo realistic renderings in Chief Architect & Lumion softwares.
      I have a well established portfolio of the houses that I’ve done, renders in lumion
      and other references as well.
      I would love to discuss your next design project with you, and even do a free online meeting, for us to get better aquanted with your Project. My professional rates are reasonable, depending on the size of the project, and the scope of the work, but I normally take payment on PayPal, and block out prepayment, for lesser amounts of time, or discuss, working on larger projects on contract basis. Pls, reach out to me, so, that we can discuss things further?
      Douglas Burgmann
      Chief Architect Designer III
      Accurate Asbuilts & Design
      Email: douglasburgmann@gmail.com
      cell:     (970)987-4476 msg
      Web:   http://www.dcbcaddesigns.com
      FB: dcb1234
    • By SpeleoWorm
      I have created a number of different wall types to show proper dimensions (i.e. when one side of the wall is 5/8" Type X and the other side is 1/2" drywall) as well as to calculate the correct material counts and to show the proper information in the schedules.  Unfortunately doing that seems to have a down side...it changes the framing as if they were separate walls instead of the same wall with different materials on them.  I have seen the following side effects (colors refer to screenshots below):
      (Green Arrow) In unfinished rooms such as an attic storage space which only has a subfloor but no drywall, the walls get pushed up into the rafters by what appears to be 3". (Red Arrows) The floor joists and top/bottom plates are cut in the middle when they should be continuous pieces of wood.  In addition, you can see that the walls which are produced are not boxed at the end...the top & bottom plates stick out at the end. (Purple Arrow) Parts of the gable wall are not created.  In this case you could argue that it is not needed, but if a builder makes a wall he is not going to leave a hole in it. (Blue Arrows) An extra stud is added to a room that has no drywall, and therefore doesn't need nailer studs.  In addition, it looks like the other stud needed as a nailer for the finished room in the middle is missing from the plan view of the framing (see 2nd screenshot).
      Am I doing this all wrong (creating separate wall types), or is there a way to use them and fix (any of) the issues I mentioned?
      Thanks in advance for any help!
      PS - I am a little surprised that the wall finish is not part of the room settings (like the floor & ceiling already are)...that would allow you to have continuous walls and still have different materials in each room (i.e. greenboard in the bath, 5/8" type X in a garage, unfinished in an attic, etc.
      Example of Wall Issue.plan
    • By PPRGLLC
      I usually print layouts on 24"x 36" paper so that is what my layout template is set up to do. A client wants to print on 11"x 17". When I change the size of the drawing sheet, it changes the paper size without adjusting the title boxes, notes, etc. Is there a way to resize the entire layout without creating a new layout template for 11" x 17" paper?
    • By HDbyJustin
      The architect I am moonlighting for wants the title sheet to be rotated 90° to the rest of the sheets. I am not sure this is possible without creating a new layout just to have the title sheet be in the correct orientation. Is this an accurate assumption?
