Jay_on_Cape Posted March 15, 2016 Share Posted March 15, 2016 Hello All, I've never run into this problem before. I'm drawing a post and beam with sip panel barn. It has a dormer which will not have sip panels so the dormer wall at the corner where it meets the sip panel gable has an issue with the siding meeting at the corner. I originally defined the posts layer as an exterior layer but moved it to an inside layer but that did not help. Does anyone have a suggestion? Thank you. SIP Corner problem.zip Link to comment Share on other sites More sharing options...
Solution dshall Posted March 15, 2016 Solution Share Posted March 15, 2016 See if this helps. I changed the main wall layer on one of the walls.... I really don't know what I did, but it looks better. cape plan 2.plan Link to comment Share on other sites More sharing options...
RayCas Posted March 15, 2016 Share Posted March 15, 2016 Hi Jay how about structure tab, wall intersections, thru wall at start and end if the cheek wall extends under the roof, cut it, call out attic wall for the pcs under the roof guessing big time, Ray Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted March 15, 2016 Author Share Posted March 15, 2016 See if this helps. I changed the main wall layer on one of the walls.... I really don't know what I did, but it looks better. Scott, Thanks for looking at it! I couldn't open it because I'm still in X7 but I'm sure I'll get X8 running this weekend. Your comments made me look at main layers and on the SIP wall I didn't have an exterior layer so I bumped the siding to the exterior layer and it works. Thanks again!!! Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted March 15, 2016 Author Share Posted March 15, 2016 See if this helps. I changed the main wall layer on one of the walls.... I really don't know what I did, but it looks better. Do I get a cookie or dog biscuit for posting the plan with a picture without being asked?...... Link to comment Share on other sites More sharing options...
dshall Posted March 15, 2016 Share Posted March 15, 2016 Do I get a cookie or dog biscuit for posting the plan with a picture without being asked?...... Yes you do. It is so nice when the plan is posted, thank you. Sorry about the X8 thing. But you did get it solved, that is super. Link to comment Share on other sites More sharing options...
