Importing Acad Elevation 'point's
dwelldesign
I've run into this a few times now and I always work around it and have not had the chance to resolve how to do this properly.  I have the ACAD survey base drawing.  All elevation shots are on the drawing as ACAD 'point's.  They are valid points with X height information. The ACAD file is in metric units, CHief is imperial - but I am importing it with unit specified on the import (the terrain perimeter imported from the same ACAD file came in correctly).  When I attempt to import these 'point's - they do not import no matter what I try!
ps. I turned on all layers & filled window in the view to make sure they are not hiding somewhere.....
Help! Attached is the dwg file with the points
X8 User
Grade Points.zip
