tahoebrian5 Posted December 17, 2015 Share Posted December 17, 2015 I know this has been covered a bit and I've read through a few threads. I see how you can change foundations to dashed or turn them off with layer sets but the problem is usually there is a little bit of the stem wall that is above grade. What would I do If I want to dash or hide only portions of the footing and stem walls that are below the top surface of grade? Also how are you guys going about adding an earth hatch pattern below the finish grade line? Just cad objects or is there a smart way? Btw, this is in reference to an elevation view that has been sent to layout. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 17, 2015 Share Posted December 17, 2015 This thread should answer your questions... https://chieftalk.chiefarchitect.com/index.php?/topic/6788-elevation-drawings-without-sub-grade-crap-showing/?hl=%2Bbelow+%2Bgrade Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 17, 2015 Author Share Posted December 17, 2015 Perfect, thanks a bunch Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 17, 2015 Share Posted December 17, 2015 You bet Link to comment Share on other sites More sharing options...
