zowie123 Posted November 20, 2015 Share Posted November 20, 2015 Hi All, Imported DWG....line colors can't be changed. When I look at the properties of the yellow line...Ext-Walls, it says it's black, but it's yellow on the screen. If I choose a different color for them, they won't change to that color? I imported them with default settings. Each on it's own layer.... Attached is the plan and an image. Thanks for considering. Cheers! Barry DWG CAD import.zip Exsiting Wall Yellow Example.zip Link to comment Share on other sites More sharing options...
zowie123 Posted November 20, 2015 Author Share Posted November 20, 2015 never mind, I got it....I was going into object layer properties as apposed to line specifications. Thank you anyway Link to comment Share on other sites More sharing options...
