yusuf-333 Posted October 13, 2015 Share Posted October 13, 2015 Here is an other way of niche insert in walls, in chief workflow is an other important factor to effectively use the tools provided so far. Last time we have seen two walls forced on top of an other wall, that process is avoided by using copy to clip board. Steps 1 place the wall 2 copy to clipboard 3 apply material region on wall 4 paste hold position and insert the niche(made from window) as explained last time. For shower niches with no casing or framing use pass thru window with no casing no frame etc..... Here is a video on this concept. https://youtu.be/GKlhRCW6Y5A Link to comment Share on other sites More sharing options...
