shanecarman Posted September 7, 2015 Share Posted September 7, 2015 Hello, I am trying to add porches to a commercial building. For some reason, a white, rectangle box stays on the second floor porches, even when "roof and ceiling over this room" are unchecked. I have attached images for examples. Any thoughts? Thank you! Shane Carman Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 7, 2015 Share Posted September 7, 2015 Can you attach the plan? Definitely looks like a ceiling. Also looks like you might be selecting the wrong room. Link to comment Share on other sites More sharing options...
WendyatArtform Posted September 7, 2015 Share Posted September 7, 2015 From that first image it looks like you have a bigger area selected, and that you need to select the area inside the railing and make sure that doesn't have a ceiling. Link to comment Share on other sites More sharing options...
shanecarman Posted September 7, 2015 Author Share Posted September 7, 2015 Here is the file. Thank you! Main Street Style Building for City Concept.planFetching info... Link to comment Share on other sites More sharing options...
shanecarman Posted September 7, 2015 Author Share Posted September 7, 2015 On 9/7/2015 at 4:01 AM, solver said: Check your ceiling finish. It's 10+ inches with a large air gap. That worked! Thank you! Link to comment Share on other sites More sharing options...
