PitMan71 Posted 5 hours ago Share Posted 5 hours ago I’m trying to understand why building the foundation changes the first-floor default floor elevation from 0" to -8" in the attached plan. I’m using Chief Architect X18 with Auto Rebuild Foundation enabled. Here’s what I’m seeing: Without the foundation built, the first-floor default floor elevation shows 0". With the foundation built, that default shows -8". The actual floor elevations in the plan appear to remain unchanged. The garage floor is 8" below the main house floor, at -8", which seems to be the only correlation I can find to the changed default. If the garage is driving this, why would its lowered floor become the first-floor default instead of remaining an exception to the main house floor at 0"? Before the foundation is built, the default reflects the main house level, which is what I would expect. Although nothing appears to move, this affects pony wall heights relative to the default floor elevation. To position a pony wall transition 4" below the main house floor, I now have to enter +4" instead of -4", because the default reference has shifted to -8". Am I missing a setting that controls this, or is this expected behavior when the foundation is built? It’s confusing to have the default reference change automatically while the main house floor remains at 0". Any insight would be appreciated. 260036-XX 11-24-2026.zip Link to comment Share on other sites More sharing options...
