TCB_BdnMY Posted 18 hours ago Share Posted 18 hours ago (edited) Hey there folks just wondering if anyone else is running into this issue where with beams in X18. When i paste the floorplan into an clean CA template file it works fine... Any ideas what settings to check? It is doing this in pretty much every room type right now, inside or outside. Edited 18 hours ago by TCB_BdnMY Link to comment Share on other sites More sharing options...
Solution mLongChief Posted 17 hours ago Solution Share Posted 17 hours ago 14 minutes ago, TCB_BdnMY said: Hey there folks just wondering if anyone else is running into this issue where with beams in X18. When i paste the floorplan into an clean CA template file it works fine... Any ideas what settings to check? It is doing this in pretty much every room type right now, inside or outside. Are your floor/ceiling platforms set to build with trusses? There is a known bug with Floor/Ceiling Beams when trying to create them when all the Floor/Ceiling Structure (the specific room you're building in, and the defaults) are set to build with trusses. Assuming you're running into that bug, it should be fixed in the next update. In the meantime, you could temporarily change you Floor Structure to build with Joists, draw your beams, then turn your Floor Structure back into trusses. 1 Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted 17 hours ago Author Share Posted 17 hours ago it was exactly this! Thank you. Link to comment Share on other sites More sharing options...
