Help Trouble with stairwell
BeeoHat
Go to solution Solved by BeeoHat,
After installing the stairs and landing on the first floor, I tried to create the Auto Stairwell, but got the following msg'
"Could not connect new stairwell railings to some of the existing walls or ceilings, so could not make the "open below" stairwell room. If you connect these railings to the appropriate walls you can then make the new room yourself".
So then i went to the second floor, and designated the "stairwell area" room as "open below". But this resulted in some weird holes in the outside wall, as shown in the attached image.
I've attached a zipped plan file. Any help would be appreciated.
House IV.zip
    32670
    gydfre
    gydfre
