msmith964 Posted June 11 Share Posted June 11 Hello, Sometimes when I created a mulled unit with a door and 2 side lites, it adds casing below the door. Does anyone know how to prevent this? I have tried turning off casing before mulling but it makes no difference. thanks! Michelle Pro 16 Link to comment Share on other sites More sharing options...
JonathanK Posted June 11 Share Posted June 11 Are you using three doors (one hinged and two fixed)?...and are the doors all set to 0" from floor to bottom before you mull them? The only way I can duplicate the issue is by setting the sidelites off the floor. If you have a plan that has the issue, zip it up and send it over. 1 Link to comment Share on other sites More sharing options...
