winterdd Posted Saturday at 04:28 PM Share Posted Saturday at 04:28 PM Hey guys, how do I get rid of this railing wall bottom when a carport is attached to the home and rear porch/deck? Hope the screenshots help...... Rear porch was made with railing walls and named "deck". I like to use railing walls to form a carport and remove the railing then manually input the posts and beams. Home subfloor is 36" above grade and carport space was formed with -35" floor height so the slab sits slightly above grade. Link to comment Share on other sites More sharing options...
tundra_dweller Posted Saturday at 04:54 PM Share Posted Saturday at 04:54 PM @winterdd You could try unchecking "generate between platforms" in the structure tab of those railing dbx's, if it's not unchecked already. Link to comment Share on other sites More sharing options...
