LeeDrafter
Hello,
I am working on a tri-level plan (attached), and I am wishing I would have drawn my 1st floor on floor 0 as a basement. The reason is the way I did it leaves a blank area for the middle floor on "Floor 1" instead of showing the foundation crawl space there, and the way I did it doesn't show the foundation below my floor framing for that middle floor. In the past, I've drawn tri-level plans with my basement level on floor 0 and within the foundation plan, but for some reason I did it differently in this plan. Is there a way to easily change floor levels? Also, which levels would you all recommend using if you were designing a tri-level like this?
thank you,
Lee
Small Townhome 38MV.zip
  • 2 weeks later...
Posted (edited)
On 3/20/2026 at 8:09 PM, Renerabbitt said:
See video solution:
thank you Rene! this was very helpful! I really appreciate your efforts in making the video, that helped a lot!
Edited by LeeDrafter
