LeeDrafter Posted 9 hours ago Share Posted 9 hours ago Hello, I am working on a tri-level plan (attached), and I am wishing I would have drawn my 1st floor on floor 0 as a basement. The reason is the way I did it leaves a blank area for the middle floor on "Floor 1" instead of showing the foundation crawl space there, and the way I did it doesn't show the foundation below my floor framing for that middle floor. In the past, I've drawn tri-level plans with my basement level on floor 0 and within the foundation plan, but for some reason I did it differently in this plan. Is there a way to easily change floor levels? Also, which levels would you all recommend using if you were designing a tri-level like this? thank you, Lee Small Townhome 38MV.zip Link to comment Share on other sites More sharing options...
Renerabbitt Posted 3 hours ago Share Posted 3 hours ago 6 hours ago, LeeDrafter said: thank you, See video solution: Link to comment Share on other sites More sharing options...
