Wall Connection Help
Dave13
I've got a old Yale dorm building that are being transformed into a prison transition dorm. The angled wall connections are giving me fits. The attached plan shows the problem area along with a quick cad detail of what I'm trying to acheive. I not that concerned if the furring connects at a angle at the brick wall but I do need to get the brick connected properly for renderings. Help
Running Cheif X7
Yale prison transition bldg.plan
You can get the corner you want if you make the wall straight and use the Chief angle bay window under the window tools.  Then you can specify the angle, depth and wall type.
You will have to modify each of the windows manually though which is kind of a pain.
Hope that helps.
